Third party software and hardware support forums. => Contec => Topic started by: sparkie.m on May 02, 2020, 10:59:51 PM
Hi all, I have A Cincinnati Milacron machine running two PIO16/16t cards and a Galil motion controller. The software is Camsoft and I am changing it to run on Mach3. Mach3 is loaded and the Galil plugin and Contec plugin and working good. The Contec cards mainly run the 24 tool ATC and I would like to make a macro in Mach3 to run it like Camsoft does. The problem is I do not have enough user input/output controls in the Ports & Pins menu in Mach3. There are 15 user inputs and 20 user outputs from memory. Can i add more somehow so i can use all 32 inputs and 32 outputs on my Contec Cards.
Cheers,
Mark
