Hello Guest it is November 03, 2026, 06:36:30 AM
Author Topic: Incorrect working space  (Read 12864 times)
« on: May 01, 2020, 04:19:52 PM »
Hello everyone,
I am quite new to CNC and am almost ready to fire up my plasma cutter. In familiarizing myself with the table and software, I have found that when I load a G-code into my Mach3 it loads the outside of my work zone. The rectangle is supposed represent my work zone (obviously) but it can very depending on where I have my torch located when I load the G-code. When referenced to zero, the torch is actually outside of the work zone (though, that is less of an issue, I think).
I am using a 5'x10' OEM setup with their custom Mach3 profile.
If there is any resources you think I should look into to become a more proficient CNC user, I would be more than happy to look into it. I just can't afford official training yet ($1200+ a day). I am currently watching the tutorials and am gleaming what I can from them.
Thanks!
Kevin Terral
Re: Incorrect working space
« Reply #1 on: May 02, 2020, 07:50:10 AM »
do you have home switches on your machine?.
From what you have described you are not referencing or homing your machine, and note that is different
to 'zeroing the work coordinates'.
« Reply #2 on: May 03, 2020, 05:52:12 PM »
I do have homing switches. I will have this problem even after I "Reference all home." The design will always load outside of the workable area. I am still watching the tutorials so I still have a chance of coming across what is causing this.
