Hello Guest it is October 24, 2026, 06:23:40 PM
Author Topic: Mach4 forgets the spindle speed after stopping a program  (Read 5838 times)
« on: April 30, 2020, 05:23:14 PM »
Is there a way to avoid that mach4 forgets the current spindle speed setting after stopping a program. Sometimes I need to stop a program somewhere into it, and when I then start up the program again (from where I stopped it), the spindle will start at its default lowest speed.  In order to fix this, I need to issue an S command on the MDI every time before starting within a program. This annoys me, as I see no reason why the spindle speed is reset at stop.
Re: Mach4 forgets the spindle speed after stopping a program
« Reply #1 on: April 30, 2020, 07:10:03 PM »
if you use <FeedHold> rather than <Stop> then yes its possible.
Look in Mach's Control plugin, in the General Setting tab, there you will find settings to determine what happens to the spindle when a <FeedHold>
is encountered.
« Reply #2 on: May 02, 2020, 12:08:06 AM »
see attached.
