Hello Guest it is October 22, 2026, 10:31:07 PM
Author Topic: Can’t get macros to work  (Read 5317 times)
« on: April 26, 2020, 12:34:00 PM »
Hi all-
I am rebuilding my CNC flame cutter.   I switched from Mach3 to Mach4.
I am needing help with the macros to turn the solenoids on and off.
I found an example in the macro section and modified it to work.
When I use the macro editor and press the play button, it works as it should .   The solenoid turns and off .
When I save the file in my macro folder, and try to run a m201 nothing happens.   If I use m7 or m8 then it turns on the M7 an M8 indicator in mach4.
So I am doing something wrong.
Can someone help?
Steve
Re: Can’t get macros to work
« Reply #1 on: April 27, 2020, 08:12:53 AM »
There are quite a few people here that can help you get your code working. Can you start by writing out a detailed functional description of how you want your solenoid to behave including any edge cases? There are a lot of ways to skin a cat in Mach 4 so you might get some varying answers. Once you do that, I'll give it a go and see what I can come up with.
-Mike
