Hello
Guest
it is
November 13, 2026, 08:31:06 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
zero axis within program
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: zero axis within program (Read 9252 times)
comet
338
on:
April 09, 2020, 09:48:59 PM »
Hi I need to zero the Z axis, automatically, at the start of a lathe program, I cannot use g90/91 because of the profile, any Ideas?
the lathe is a swiss auto bar feed is the z type machine.
cheers
Graham Waterworth
2,785
Yorkshire Dales, England
Re: zero axis within program
Reply #1 on:
April 11, 2020, 06:43:05 PM »
G92 but use with caution
comet
338
Reply #2 on:
April 12, 2020, 04:49:43 AM »
Cheers Graham I will try that. Why do you need to use caution? Any other Tips
Happy Easter !!
Tony
Quote from: Graham Waterworth on April 11, 2020, 06:43:05 PM
Graham Waterworth
2,785
Reply #3 on:
April 12, 2020, 07:55:44 PM »
Depending on where you put it in the code if you have to stop the program and restart you could end up in the wrong place.
Its normally used in rotary axis work to zero out the indexer to stop unwinding.
comet
338
Reply #4 on:
April 13, 2020, 04:49:38 AM »
That works a treat, exactly what I needed thanks.
Tony
Print
Pages:
1
Go Up
« previous
next »
