Hello Guest it is November 13, 2026, 08:06:02 PM
Author Topic: zero axis within program  (Read 9249 times)
Offline comet
  •  338 338
« on: April 09, 2020, 09:48:59 PM »
Hi I need to zero the Z axis, automatically, at the start of a lathe  program, I cannot use g90/91 because of the profile, any Ideas?
the lathe is a swiss auto bar feed is the z type machine.
cheers
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: zero axis within program
« Reply #1 on: April 11, 2020, 06:43:05 PM »
G92 but use with caution
Offline comet
  •  338 338
« Reply #2 on: April 12, 2020, 04:49:43 AM »
Cheers Graham I will try that. Why do you need to use caution? Any other Tips
Happy Easter !!
Tony
  •  2,785 2,785
« Reply #3 on: April 12, 2020, 07:55:44 PM »
Depending on where you put it in the code if you have to stop the program and restart you could end up in the wrong place.
Its normally used in rotary axis work to zero out the indexer to stop unwinding.
Offline comet
  •  338 338
« Reply #4 on: April 13, 2020, 04:49:38 AM »
That works a treat, exactly what I needed thanks.
Tony
