Hello Guest it is November 22, 2026, 06:21:17 PM
Author Topic: Homing and Limits  (Read 8424 times)
Homing and Limits
« on: April 02, 2020, 08:51:03 AM »
At the moment my machine is unavailable due to a workshop refurb.
Can anyone confirm whether Limits are enabled or disabled during Homing? If they are disabled then I have a dangerous situation if I have a wiring fault on the Homes as they are NO inductive switches. The Limits are NC microswitches, so that would provide a safety net.
Rob
Re: Homing and Limits
« Reply #1 on: April 02, 2020, 10:39:04 AM »
Hi Rob.
Of course, limits are ignored if the limit sw also acts as a home.
I tested a separate limits and home switch configuration by emulating to separate inputs and found that even though the inputs are separate, Mach3 still ignores the emulated limit sw trigger while homing.
I would think it should not be that way ... but it is what it is.
Russ
« Reply #2 on: March 12, 2021, 01:27:05 PM »
Is there any way to change this behavior? It is desirable that the limits are active when limit sw does not act as home.
thank you
T.
