Hello Guest it is September 09, 2026, 10:52:19 AM
Author Topic: HELP please Mach3 won't run my board  (Read 23609 times)
« on: September 21, 2007, 12:08:30 AM »
I'm totally new to the cnc world but i managed to make the table and a board to control the motors and i'm using this board http://pminmo.com/3axis/3axis.htm  and i tested it with another software and it spin the motors very well but when using Mach3 i can't move the motors at all i used the configuration as instructed in the board manual for pins on the LPT port and also this configuration http://www.pminmo.com/wiki/index.php?title=MACH3_setup
which is made specifically for this board with mach3 but nothing happens at all but i noticed that when i run gcode file " the road runner" and start cycle i notice very very small movements on one motor like 2 or 3 tiny tiny steps but thats all
please help me configure my board with Mach3
BTW i'm running a new computer with 3.2GHz processor if thats matter
thank you in advance
Re: HELP please Mach3 won't run my board
« Reply #1 on: September 21, 2007, 01:20:28 AM »
Go to the Mach3 folder and copy your XMLfile for the profile you are using and attach it here. If you have not made a custom profile it will be Mach3Mill.xml  Also you will have to rename it to be able to attach it to a post.
We can then have a look and see if we can find any problems in the setup.
« Reply #2 on: September 21, 2007, 07:29:49 AM »
OK here is the file
« Reply #3 on: September 22, 2007, 06:19:26 PM »
Sounds like you need to reverse your Step and direction pins...
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: September 23, 2007, 04:21:04 AM »
thank you for your reply
the step pins configured for the DB female in the board is 3 6 9 for the X Y Z and the dir pins is 2 5 8 and here is the photo for the recommended by the board maker http://www.pminmo.com/wiki/index.php?title=Image:Mach3MotorPin.png
and if you checked the xml file you will find that i configured it right i don't have a clue of whats wrong
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #5 on: September 24, 2007, 12:24:46 AM »
Hi, Maxmyo
Some printer cards, cables and cnc boards don't support/use all the same Gnd pins 18 through 25, Thy just use a couple of them.
Check that you have a good Gnd from the computer and your cnc board, I've seen this a couple of times
Hope this Helps, Chip
« Reply #6 on: September 24, 2007, 05:00:18 PM »
thanks for your concern
but like i stated the board is already working with another software and the motors spin smoothly but i would like to use mach3 to control my cnc but whatever i try the best result i get is the very tiny steps for just the Y motor thats it
i'm clueless of what to do
please any hint would be appreciated
« Reply #7 on: September 24, 2007, 08:47:25 PM »
Have you set the steps per unit values and the speed and acceleration values in the motor tuning screen? Will the motors run from the tuning screen?
« Reply #8 on: September 24, 2007, 09:19:12 PM »
thanks for your help
yes i did set the tuning motor parameters as in this picture
http://www.pminmo.com/wiki/index.php?title=Image:Mach3MotorT.png
but i don't know what do you mean by running the motors from the tuning screen
« Reply #9 on: September 29, 2007, 07:25:09 PM »
hey guys i'm waiting for along time now and Hood asked for XML file and i provided it but didn't recieve any answer so should i forget about mach3
