Mach Discussion => General Mach Discussion => Topic started by: maxmyo on September 21, 2007, 01:08:30 AM
I'm totally new to the cnc world but i managed to make the table and a board to control the motors and i'm using this board http://pminmo.com/3axis/3axis.htm and i tested it with another software and it spin the motors very well but when using Mach3 i can't move the motors at all i used the configuration as instructed in the board manual for pins on the LPT port and also this configuration http://www.pminmo.com/wiki/index.php?title=MACH3_setup
which is made specifically for this board with mach3 but nothing happens at all but i noticed that when i run gcode file " the road runner" and start cycle i notice very very small movements on one motor like 2 or 3 tiny tiny steps but thats all
please help me configure my board with Mach3
BTW i'm running a new computer with 3.2GHz processor if thats matter
thank you in advance
Go to the Mach3 folder and copy your XMLfile for the profile you are using and attach it here. If you have not made a custom profile it will be Mach3Mill.xml Also you will have to rename it to be able to attach it to a post.
We can then have a look and see if we can find any problems in the setup.
OK here is the file
Sounds like you need to reverse your Step and direction pins...
thank you for your reply
the step pins configured for the DB female in the board is 3 6 9 for the X Y Z and the dir pins is 2 5 8 and here is the photo for the recommended by the board maker http://www.pminmo.com/wiki/index.php?title=Image:Mach3MotorPin.png
and if you checked the xml file you will find that i configured it right i don't have a clue of whats wrong
Hi, Maxmyo
Some printer cards, cables and cnc boards don't support/use all the same Gnd pins 18 through 25, Thy just use a couple of them.
Check that you have a good Gnd from the computer and your cnc board, I've seen this a couple of times
Hope this Helps, Chip
thanks for your concern
but like i stated the board is already working with another software and the motors spin smoothly but i would like to use mach3 to control my cnc but whatever i try the best result i get is the very tiny steps for just the Y motor thats it
i'm clueless of what to do
please any hint would be appreciated
Have you set the steps per unit values and the speed and acceleration values in the motor tuning screen? Will the motors run from the tuning screen?
thanks for your help
yes i did set the tuning motor parameters as in this picture
http://www.pminmo.com/wiki/index.php?title=Image:Mach3MotorT.png
but i don't know what do you mean by running the motors from the tuning screen
hey guys i'm waiting for along time now and Hood asked for XML file and i provided it but didn't recieve any answer so should i forget about mach3
Hi, Maxmyo
Give this a try, Change the Dir/Steps Low Actives around.
Also have you tried the other Printer port address for Port #1, Other than std. 0x378, Tried 0x278.
Look at your other cnc program that works, Maybe it is using a different address.
Chip
Sorry for not replying :(
Had a look at the xml and first look it seems fine as far as setup is concerned, but have a look at your Steps Per Unit as they could be on the low side. Are these drives microstepping, half step or full step? What is the TPI of your ballscrew/leadscrew?
What Ron is meaning is go to Config menu then down to motor tuning. Use the sliders to increase/decrease your values for each motor and test by using the Up/Down arrows. Once you have the tuning the way you want then save the axis settings and move onto the next.
Try to activate the "Gecko half step mode" option on the Config->motor and pins tab
