Hello Guest it is November 22, 2026, 06:32:54 AM
Author Topic: No response to any CV settings in mach4  (Read 6514 times)
Offline Ow
  •  5 5
« on: March 09, 2020, 08:55:18 PM »
Just in the process of upgrading to Mach4 from mach3 and everything is working great except for Constant Velocity..
I am calling the g56 enable code and motion mode is set to constant velocity in mach's settings. I am using the same known good gcode that works great on mach3 with CV.
I have tried using the wizards to configure the CV settings and also manually adjusting it in the machine.ini file. No matter what direction I go with the settings I get no response. Machine keeps running in exact stop mode.
My machine uses an ESS with build 253 plugin and Mach4 4322.
Hopefully its a simple fix. Happy to pay for someones time to solve the problem for me!
Thanks.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: No response to any CV settings in mach4
« Reply #1 on: March 11, 2020, 07:01:38 PM »
Try using G61/G64 they control CV, G56 is a fixture offset
Offline Ow
  •  5 5
« Reply #2 on: March 12, 2020, 09:45:12 AM »
Hey Graham thanks for the reply. Yeah I am using g61/g64 I guess I just noted wrong code in my post.
