Hello Guest it is November 23, 2026, 05:06:49 AM
Author Topic: New guy needing an assist. I have movement, but its very tiny.  (Read 19418 times)
New install. I have the unit set in mach3 for inches. Created a file in Aspire 10. Uploaded the file into Mach3 on Vista machine with windows 7 upgrade. All looked good so I hit run.  Code runs, I get movement but its very, very small movement.  I have a setting wrong someplace...  post processor is Mach3 2/3 arcs Inch  ( not sure if that is the correct one to use) ---  ideas, suggestions?
Thanks in advance
Novice
Specs:
6040Z
Windows 7
Aspire 10.0
Mach 3
G540
Mach3 2/3 arcs Inch
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
Mach 3 - Ver 3.043.066
G540 Rev 5
Post Processor: Mach3 2/3 arcs (Inch)
Motors-57BYGH433-06BS
  •  9,378 9,378
Re: New guy needing an assist. I have movement, but its very tiny.
« Reply #1 on: March 07, 2020, 12:31:17 AM »
Try running the Axis Calibration routine (Settings page) to check that you have your Steps per Unit set correctly for each axis. It is simple to use, just follow the on-screen instructions.
« Reply #2 on: March 07, 2020, 10:26:11 AM »
I redid this morning. Came back with same settings as before.  :(
X & Y
steps- 400
Velocity 3000
Acceleration 425
Material size on file shows as X=10.0 Y=10.0 Z=0.99
Actual cut size is about 3/4 inch square...... 10 inch is about 254 mm so its not just switching to mm somehow
I can manually run table entire width and length. Tried multiple files all run tiny.  Machine is set to Inch. Aspire is set to Inch. Files show to be Inch.
Thanks for any help, ideas or things to try
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
G540 Rev 5
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
G540 Rev 5
Offline ZASto
  •  434 434
« Reply #3 on: March 07, 2020, 12:47:54 PM »
It looks that your Mach3 is set to millimeters. If you are happy with speed/acceleration, set Mach3 to Inches and in motor tuning multiply Steps per, Velocity and Acceleration FOR EACH AXIS by 25.4 so, for X and Y:
Steps: 10160
Velocity: 118
Acceleration: 16
My personality is who I am.
« Reply #4 on: March 07, 2020, 08:17:12 PM »
Thanks guys.  I'm going to reinstall mach3 and see if it makes it better.   I'll let you know how it goes next weekend.
Specs:
6040Z
Dell Optiplex 760
Windows 7 Ultimate
Aspire 10.0
G540 Rev 5
