Hello
Guest
it is
November 22, 2026, 03:40:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Cutter compensation not working (Fusion 360 and Mach3)
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cutter compensation not working (Fusion 360 and Mach3) (Read 7483 times)
kvid
25
on:
February 27, 2020, 11:12:58 AM »
I have tried to implement cutter compensation for a while but never had any luck.
Whatever I do I always get some errors in Mach3.
I made a short recording that goes trough programming a part and importing it into Mach3. I would appreaciate any tips and suggestions.
https://youtu.be/3ZeYL-pW3V8
I attached the g-code and the fusion archive file.
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Cutter compensation not working (Fusion 360 and Mach3)
Reply #1 on:
February 28, 2020, 09:00:02 AM »
Mach3 needs a lead in and lead out with a line and radius the rad must be tool rad plus a bit and line length has to be tool rad plus a bit so if using a 10mm dia end mill lead in line could be 6mm and rad 6mm then all should be good.
Logged
Print
Pages:
1
Go Up
« previous
next »
