Hello Guest it is October 10, 2026, 04:36:04 PM
Author Topic: Mach3 won't move anything on my 3040t  (Read 11905 times)
« on: February 20, 2020, 09:20:32 PM »
I am using a UC-100 to connect the cnc with the HP PC. it's running Win8.1. When I boot the software the UC-100 led lights go on (gree, blue solid).  I can see the UC-100 in it's monitoring window.  The only thing that works is the estop.  I can click on reset and the blinking goes away.  Is there anything in the settings input, outputs etc., that could be enterer wrong?  I have tried alot.  Can someone please help me to setup my 3040t CNC!  I think it should work!
Tom Megna
Re: Mach3 won't move anything on my 3040t
« Reply #1 on: March 05, 2020, 09:19:04 AM »
Looking at the UC100 docs, a blinking blue and only Estop working appears to be a CPU load issue.
What is shown in the mach3 status window.. UC100 sync error?
Have you setup Mach3 with proper port/pins etc... correctly?
looking at the UC monitor window, can you see any of the mach3 functions working while using the mach3 control screen?
