Mach Discussion => General Mach Discussion => Topic started by: tommegna on February 20, 2020, 10:20:32 PM
I am using a UC-100 to connect the cnc with the HP PC. it's running Win8.1. When I boot the software the UC-100 led lights go on (gree, blue solid). I can see the UC-100 in it's monitoring window. The only thing that works is the estop. I can click on reset and the blinking goes away. Is there anything in the settings input, outputs etc., that could be enterer wrong? I have tried alot. Can someone please help me to setup my 3040t CNC! I think it should work!
Tom Megna
Looking at the UC100 docs, a blinking blue and only Estop working appears to be a CPU load issue.
What is shown in the mach3 status window.. UC100 sync error?
Have you setup Mach3 with proper port/pins etc... correctly?
looking at the UC monitor window, can you see any of the mach3 functions working while using the mach3 control screen?
