Hello Guest it is November 13, 2026, 05:01:53 PM
Author Topic: THREADIDNG ISSUES  (Read 21107 times)
THREADIDNG ISSUES
« on: February 19, 2020, 01:09:30 PM »
So I made my machine cut a thread . I cut a 20 threads per inch. The problem is I had to change my motor tuning to run at .050 per inch the motion controller was feeding the machine to fast my acceleration was at 50 and it cut 5 threads per inch . Whats the deal .The motion controller sees the spindle speed .It knows the motor tuning .Why wont it feed correctly? I need some support please.
Re: THREADIDNG ISSUES
« Reply #1 on: February 24, 2020, 09:53:31 AM »
Good morning gabedrummin,
It would be helpful if you posted the code you used to attempt to thread.  Did you write it yourself? Post that code.  Was it generated by a threading wizard? Attach a screen shot of the settings used.
Are you using Mach3 or Mach4?
More info gets more help.
RT
« Reply #2 on: July 26, 2021, 11:33:17 AM »
The problem was fixed it was a hardware issue.
