Third party software and hardware support forums. => PoKeys => Topic started by: gabedrummin on February 19, 2020, 02:09:30 PM
So I made my machine cut a thread . I cut a 20 threads per inch. The problem is I had to change my motor tuning to run at .050 per inch the motion controller was feeding the machine to fast my acceleration was at 50 and it cut 5 threads per inch . Whats the deal .The motion controller sees the spindle speed .It knows the motor tuning .Why wont it feed correctly? I need some support please.
Good morning gabedrummin,
It would be helpful if you posted the code you used to attempt to thread. Did you write it yourself? Post that code. Was it generated by a threading wizard? Attach a screen shot of the settings used.
Are you using Mach3 or Mach4?
More info gets more help.
RT
The problem was fixed it was a hardware issue.
