Hello Guest it is October 21, 2026, 05:56:40 PM
Author Topic: How to disable any movement before the machine is homed?  (Read 17936 times)
Offline kvid
  •  25 25
« on: February 16, 2020, 12:10:34 PM »
How can I disable any motion before the machine is homed?
Re: How to disable any movement before the machine is homed?
« Reply #1 on: February 16, 2020, 05:28:03 PM »
make flag ,for example registry can be for this
Offline kvid
  •  25 25
« Reply #2 on: February 16, 2020, 05:37:58 PM »
I am sorry but I don't understand what you are talking about. Please explain.
« Last Edit: February 16, 2020, 05:42:01 PM by kvid »
« Reply #3 on: February 16, 2020, 06:31:44 PM »
can create registry as 0 then when homing finish change to 1
and in jog add condition only if that registry is 1,also when its 0 put machine in hold ,so cant move
« Reply #4 on: February 16, 2020, 07:50:03 PM »
That's easy,  in the screen load script or the first run of the PLC script deactivate any and all servo/stepper enables.
But now what? You want to home your machine....but you can't you have just disable ALL movement.
What you really want is to stop any MDI commands, any Gcode jobs or any jogging to occur before the machine is homed...
am I correct?
Offline kvid
  •  25 25
« Reply #5 on: February 17, 2020, 02:37:32 AM »
Ok, I think I understand the concept but I don't have any experience with coding in LUA.
am I correct?
I should have explained what I am trying to do a little better.
I created a simple screenset for production which contains only what is necesarry. I am trying to prevent the worker who is working on the machine from accidentaly running the program with Cycle Start before he has homed the machine with Reference All Axes Home button.
I attached the screen.
« Last Edit: February 17, 2020, 02:39:07 AM by kvid »
« Reply #6 on: February 20, 2020, 05:25:52 PM »
Simply put a sign on the computer.... Machine Must be Homed before any other movement!
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
Offline smurph
  •  1,575 1,575
« Reply #7 on: February 20, 2020, 06:53:42 PM »
This.  Simply brilliant!!!  :)
Way back when, I was a systems analyst.  Believe it or not, systems analysts existed before computers got so accessible/popular.  System analysts were basically problem solvers when trying to improve any system, be it a manual or automated system of any type.  It could be logistics flow of material through a plant, or simply how to keep track of shipment items when they are loaded onto a truck.  And later on when computers became "the way" to solve problems, everyone wanted to do things that way.  But sometimes, the more direct approach was the cheaper and BETTER solution.  A sign is cheap.  Nothing more simple or direct than that.  And a lot of times, that simpler and more direct approach was job training.
So I found myself becoming a big proponent signs and training!
But I'm not ignoring the fact that sometimes a completely automated means to force a certain behavior is a bad idea.  I like shock collars.  LOL
All that being said, here is my implementation of the no motion before home op.:
The following functions are put in the Screen Load script.
Code: [Select]
function InhibitMotion(inhibit)
    local inst = mc.mcGetInstance('InhibitMotion()')
    local rc, hSigInhitbitMotion
    hSigInhitbitMotion, rc = mc.mcSignalGetHandle(inst, mc.ISIG_MOTION_INHIBIT)
    if (rc ~= mc.MERROR_NOERROR) then -- check retun codes!
        mc.mcCntlMacroAlarm(inst, 600, 'Could not retrieve ISIG_MOTION_INHIBIT signal handle!')
return
end
if (inhibit) then
rc = mc.mcSignalSetState(hSigInhitbitMotion, 1) -- raise the mc.ISIG_MOTION_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 602, 'Could not set ISIG_MOTION_INHIBIT signal state to 1!')
return
end
else
rc = mc.mcSignalSetState(hSigInhitbitMotion, 0) -- lower the mc.ISIG_MOTION_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 604, 'Could not set ISIG_MOTION_INHIBIT signal state to 0!')
return
end
    end
end
function InhibitJog(inhibit)
    local rc, hSigInhitbitJog
    hSigInhitbitJog, rc = mc.mcSignalGetHandle(inst, mc.ISIG_JOG_INHIBIT)
        mc.mcCntlMacroAlarm(inst, 601, 'Could not retrieve ISIG_JOG_INHIBIT signal handle!')
return
end
if (inhibit) then
rc = mc.mcSignalSetState(hSigInhitbitJog, 1) -- raise the mc.ISIG_JOG_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 603, 'Could not set ISIG_JOG_INHIBIT signal state to 1!')
return
end
else
rc = mc.mcSignalSetState(hSigInhitbitJog, 0) -- lower the mc.ISIG_JOG_INHIBIT signal
mc.mcCntlMacroAlarm(inst, 605, 'Could not set ISIG_JOG_INHIBIT signal state to 0!')
return
end
    end
end
function InhibitMotionAndJog(inhibit)
InhibitJog(inhibit)
end
function CheckHomed()
    local inst = mc.mcGetInstance('CheckHomed()')
    local homedX, homedY, homedZ, homed, rc, hSigInhitbitMotion, inhibitMotion
    homedX, rc = mc.mcAxisIsHomed(inst, mc.X_AXIS)
        mc.mcCntlMacroAlarm(inst, 5000, 'Could not retrieve X axis homed condition!')
return
end
    homedY, rc = mc.mcAxisIsHomed(inst, mc.Y_AXIS)
        mc.mcCntlMacroAlarm(inst, 5001, 'Could not retrieve Y axis homed condition!')
return
end
    homedZ, rc = mc.mcAxisIsHomed(inst, mc.Z_AXIS)
        mc.mcCntlMacroAlarm(inst, 5002, 'Could not retrieve Z axis homed condition!')
return
end
        mc.mcCntlMacroAlarm(inst, 5003, 'Could not retrieve ISIG_MOTION_INHIBIT signal handle!')
return
end
    inhibitMotion, rc = mc.mcSignalGetState(hSigInhitbitMotion)
        mc.mcCntlMacroAlarm(inst, 5005, 'Could not retrieve ISIG_MOTION_INHIBIT signal state!')
return
end
homed = homedX and homedY and homedZ
if ((homed == 0) and (inhibitMotion == 0)) then
InhibitMotionAndJog(true)
elseif ((homed == 1) and (inhibitMotion == 1)) then
InhibitMotionAndJog(false)
    end
end
And put this one liner in your PLC script:
Code: [Select]
CheckHomed()
Steve
Offline smurph
  •  1,575 1,575
« Reply #8 on: February 20, 2020, 06:54:30 PM »
Also, the PMC could be used to accomplish the same thing.
Steve
Offline smurph
  •  1,575 1,575
« Reply #9 on: February 20, 2020, 11:20:16 PM »
Yeah...  the PMC rules for this kind of stuff.  It is a one rung'er.  :)
Unfortunately, I broke the PMC editor in builds 4394 to 4410.  A new dev build will be there soon.  But you can try it out just dropping the .pmc and .lua files in your Pmc directory and then telling the screen set to use them.  Like I said, only the PMC Editor was broken.  I tried to get fancy and had an epic failure.  LOL
Both the scripts above and this pmc file raise ISIG_MOTION_INHIBIT (Gode/MDI) and ISIG_JOG_INHIBIT (jogging).
Steve
« Last Edit: February 20, 2020, 11:23:40 PM by smurph »
