Hello
Guest
it is
November 29, 2026, 02:09:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Mach4 Plugins
Stupid Vista Plug in, S and V reversed
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Stupid Vista Plug in, S and V reversed (Read 24681 times)
wmgeorge
198
on:
February 11, 2020, 04:40:18 PM »
My Vista M1 Pendent worked fine in Mach3 and Mach4 until I changed the setup file and screen set to use the CNCRP / Avid setup so I could use their Auto Zero pad. It all works fine Except the S & V on the Pendent are now reversed. I used the plug in file from the old Mach4 build but same old thing.
Suggestions or clues of where else to look??
Retired Master Electrician, Commercial HVAC/R Service and lots of Hobbys.
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Stupid Vista Plug in, S and V reversed
Reply #1 on:
February 11, 2020, 06:02:04 PM »
Swaping the wires in the pendant would work
wmgeorge
198
Reply #2 on:
February 11, 2020, 06:07:20 PM »
Yes, I thought of that but I was just looking for a check or un-check solution. I will need to haul out my little Heathkit soldering iron, its served me well. Built lots of ham radios back in the day!! Thank you.
wmgeorge
198
Reply #3 on:
February 11, 2020, 06:45:50 PM »
Nope its all a PC board, nothing to swap.
Stuart
311
Reply #4 on:
February 12, 2020, 02:29:58 AM »
Look at the last thing you changed before you noticed the errata
I would look at the logic in the screen set that is different to the one you had in before
wmgeorge
198
Reply #5 on:
February 12, 2020, 07:01:23 AM »
Stuart Please see above. Why would screen set have anything to do with pendent?
Stuart
311
Reply #6 on:
February 12, 2020, 08:04:55 AM »
Yes I read that
But is the pendant correct and your prev screen dro wrong eg pointing at the wrong location or is the new one wrong
For example the industrial screen a year ago had the override sliders incorrectly addressed .
Ok question what in machine reactions not the screen dro happen when you use the pendant .
A lot of addresses have been changed in Lua in recent times . As I use the old industrial screen ( yes I do have a valid lic.) I often have to do a compare with the current screen when things go pear shaped ,eg the last but one dev rel. stopped the tool offset from working but a quick cut and past from the as delivered screen sorted it out
Hope you can sort it but have you contacted vista for info on the m1 may need a plug in update or a firmware update
wmgeorge
198
Reply #7 on:
February 15, 2020, 06:35:50 PM »
The V & S functions on the M1 Pendant just control wither the function is either in the S step by step mode speed or V velocity or constant speed mode. I have contacted the folks at both Avid and VistaCNC
In the mean time I have ordered a wireless keypad and will use the keyboard function to do my pendant thing when zeroing the work piece.
Stuart
311
Reply #8 on:
February 16, 2020, 01:48:30 AM »
Please keep us updated on this as a lot of us use the vista series pendant
edcross
60
Reply #9 on:
April 02, 2020, 10:14:56 AM »
I have a p 4-s and when i jog from it any axis it will trip mach 4 v 4300 error code motion underrun 7, reset and it may work a couple times , then faults again . Wrote to zista but no reply yet .
Print
Pages:
1
Go Up
« previous
next »
