Hello Guest it is November 13, 2026, 02:08:57 PM
Author Topic: System wait macro function help  (Read 46912 times)
Re: System wait macro function help
« Reply #20 on: February 03, 2020, 05:07:14 AM »
I also try to make just half of macro working, but the same all the time.
If I can get this Half macro working then I would also manage first part of it.
I write all scripts in Mach3 VBscript editor, and for that one, when I press play button, it just plays whole macro, without waiting on GetInBit for signal.
« Reply #21 on: February 03, 2020, 05:10:09 AM »
Sorry my fault.
code corrected:
Code: [Select]
If GetOemLED(821) Then      'Bar end signal
Code "G0 G54 Z110"
ResetOutBit(90,11)  'Collet close reset
SetOutBit(90,9)     'Collet Open
        SetOutBit(90,6)     'Collet Open
        SetUserLed(1001,1)  'Set Collet open LED ON
        While Not(GetInBit(91,1))    'Wait for Start signal from Bar fedder
                Sleep(100)
        Wend
                Code "G0 G54 Z-35"
                Sleep 1000
                If GetInBit(91,1) = 0 Then     'Wait for Start signal from Bar fedder
                Sleep(100)
                End If
                ResetOutBit(90,9)   'Reset Collet Open
                ResetOutBit(90,6)   'Reset Collet Open
                SetOutBit(90,11)    'Collet Close
                Sleep 100
                SetUserLed(1001,0)  'Set Collet open LED OFF
                Sleep 2000
Else
sleep 100
                Sleep(100)
        Wend
        sleep 100
        Sleep 2000
End If
This one Works at least in VB script editor. I'll Test it on machine in few hours and let you know result.
Thank you
« Reply #22 on: February 03, 2020, 08:32:13 AM »
Sorry my fault.
code corrected:
Code: [Select]
Code "G0 G54 Z110"
                Sleep(100)
        Wend
                Code "G0 G54 Z-35"
                Sleep 1000
                Sleep(100)
                End If
                Sleep 100
                Sleep 2000
Else
sleep 100
                Sleep(100)
        Wend
        sleep 100
        Sleep 2000
End If
Thank you
Well, this is working, but there must be no Sleep in middle of Whille and Wend. Like this:
              Wend
But Unfortunately this didn't solve my problem. Still some times don't get input. Led on CSMIO controller illuminates, but looks like in program doesn't detect it. I also try different inputs, but always the same result.
It really is frustrating. Whole retrofit end up terrific, machine is working great, but without bar feeder is useless.
Do you have any clue what could be the cause of that problem?
Offline TPS
  •  2,627 2,627
« Reply #23 on: February 04, 2020, 12:34:51 AM »
do you mean macro will not wait until Input is on, or does the macro not goin Forward after Input is on?
« Reply #24 on: February 11, 2020, 05:37:14 AM »
Problem solved.
I was running .066 version of Mach3 and then TPS member suggested to try with .062 version. Well since then no problem. Looks like older version solve my problem.
Thank you
Best regards
Gasper
