Hello Guest it is November 26, 2026, 10:05:50 PM
Author Topic: System wait macro function help  (Read 47134 times)
« on: January 27, 2020, 04:26:02 AM »
I kindly asking anyone to help me with that macro. I need System wait function, but it doesn't work. What is right command to get it work?  I could get command from input 2, or OemLed 822.
I need that macro for Lathe Bar Fedder.
If GetOemLED(821) Then
   Code "G0 G54 Z110"
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1
Else
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1)
        SystemWaitFor(INPUT2)
        ResetOutBit(90,9)
        ResetOutBit(90,6)
        Sleep 100
        SetOutBit(90,11)
        SetUserLed(1001,0)
End If
Thank you
Best regards
Gasper
Offline TPS
  •  2,627 2,627
Re: System wait macro function help
« Reply #1 on: January 30, 2020, 10:02:11 AM »
Looks like you are using a CSMIO
you can use GetInBit
Code: [Select]
If GetInBit(adr, bit) = False Then
Sleep(50)
End If
« Reply #2 on: January 31, 2020, 04:49:20 AM »
Code: [Select]
Sleep(50)
End If
Thank you for answer.
If I use this it will not wait for needed input signal and then continue program.  It will continue if input wont be active. Or I'm I wrong?
Thank you
Best regards
Gasper
Offline TPS
  •  2,627 2,627
« Reply #3 on: January 31, 2020, 04:53:21 AM »
it will continue program if Input is true
Code: [Select]
   Code "G0 G54 Z110"
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1
Else
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1)
Sleep(50)
End If
        ResetOutBit(90,9)
        ResetOutBit(90,6)
        Sleep 100
        SetOutBit(90,11)
        SetUserLed(1001,0)
End If
you Need to replace "adr" and "bit" by your real values.
« Reply #4 on: January 31, 2020, 05:27:09 AM »
Code: [Select]
   Code "G0 G54 Z110"
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1
Else
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1)
Sleep(50)
End If
        ResetOutBit(90,9)
        ResetOutBit(90,6)
        Sleep 100
        SetOutBit(90,11)
        SetUserLed(1001,0)
End If
Code: [Select]
   Code "G0 G54 Z110"
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1
Else
   ResetOutBit(90,11)
   SetOutBit(90,9)
        SetOutBit(90,6)
        SetUserLed(1001,1)
Sleep(50)
End If
        ResetOutBit(90,9)
        ResetOutBit(90,6)
        Sleep 100
        SetOutBit(90,11)
        SetUserLed(1001,0)
End If
Can you please check attached macro and look what is wrong in it, coz I have sytax error.   And please repair, coz I believe there are errors in it, coz I'm beginner with marcos...
« Last Edit: January 31, 2020, 05:29:46 AM by BGelektronika »
« Reply #5 on: January 31, 2020, 05:27:39 AM »
Could we also change instead 'If GetOemLed (821)' to If GetInBit(90,16) ?
Here Is attachment.
Offline TPS
  •  2,627 2,627
« Reply #6 on: January 31, 2020, 05:38:13 AM »
Code: [Select]
If GetInBit(90,16) Then                 'Bar end signal
Code "G0 G54 Z110"              'Clear to make space for Bar fedder to push remnant out
ResetOutBit(90,11)              'Collet close reset
SetOutBit(90,9)                 'Collet Open
        SetOutBit(90,6)                 'Collet Open
        SetUserLed(1001,1)              'Set Collet open LED ON
        If GetInBit(90,17) = False Then 'Wait for Start signal from Bar fedder
                Sleep(50)
        End If
        Code "G0 G54 Z-35"              'Position stopper at top cut position
                Sleep(1000)
                Sleep(50)
        End If
        ResetOutBit(90,9)               'Reset Collet Open
        ResetOutBit(90,6)               'Reset Collet Open
        SetOutBit(90,11)                'Collet Close
        Sleep(100)
        SetUserLed(1001,0)              'Set Collet open LED OFF
        Sleep(2000)
Else
Sleep(100)
                Sleep(50)
        End If
        Sleep(100)
        Sleep(2000)
End If
« Reply #7 on: January 31, 2020, 06:14:17 AM »
Code: [Select]
                Sleep(50)
        End If
                Sleep(1000)
                Sleep(50)
        End If
        Sleep(100)
        Sleep(2000)
Else
Sleep(100)
                Sleep(50)
        End If
        Sleep(100)
        Sleep(2000)
End If
I have test it now and It does not wait for signal, it just goes forward. What I'm I doing wrong?
I really appreciate for help.
« Reply #8 on: January 31, 2020, 06:35:48 AM »
It is working!
It is not GetInBit(xx,xx)  but GetInput(xx)
« Reply #9 on: January 31, 2020, 06:52:57 AM »
Well I was wrong. It still does not wait for signal, it just goes forward. How to tell him to wait for signal to be active, and then continue?
