Hello Guest it is November 22, 2026, 06:32:36 AM
Author Topic: Settings not saving?  (Read 6987 times)
« on: January 24, 2020, 03:09:24 PM »
I can only find some mach 3 info on this which did not seem to work. After closing mach4 the changes I made are not saved. Mainly the x axis reverses and any keypad mapping I added disappears.
What I have tried so far is to right click on mach4 then made my way into the security tab and unchecked "write" under the permission section... nothing changed.
Thanks guys!
Re: Settings not saving?
« Reply #1 on: January 25, 2020, 07:16:45 PM »
Were you installing Mach4 to its default installation directory C:/Mach4Hobby/ ?
If not make sure that there are no spaces in the installation path. At first I installed it to C:/Program Files (x86)/Mach4Hobby/  but that causes many problems in regards to saving/loading files.
Best regards
Brandon
« Reply #2 on: January 28, 2020, 04:43:39 AM »
Did you solve your issue? I’m having the same problem
