Hello Guest it is November 12, 2026, 07:02:51 AM
Author Topic: X axis not working with code  (Read 10969 times)
« on: January 23, 2020, 09:24:07 AM »
Hello,
Im using the Aspire software to create my codes, and for some reason when i start the code the X appears to be moving in mm instead of inches but the Y and Z are moving just fine.  It also jogs just fine, but also when I put in G-code for any movement in X it seems to move small increments and displays the coordinates as if it moved an inch when again it only moved about a mm.
Any suggestions?
Offline ZASto
  •  434 434
Re: X axis not working with code
« Reply #1 on: January 23, 2020, 09:48:59 AM »
Is your X axis calibrated properly?
My personality is who I am.
« Reply #2 on: January 23, 2020, 09:51:46 AM »
When I jog it everything is accurate. Everything is the same as before my teardown where it was working perfectly.
Offline ZASto
  •  434 434
« Reply #3 on: January 23, 2020, 10:13:44 AM »
Attach part of G-Code that is troublesome.
« Reply #4 on: January 23, 2020, 10:17:20 AM »
I will attach my gcode later but this happens even when I manually enter a g0 x1 command.
« Reply #5 on: January 24, 2020, 07:23:33 AM »
Update:  I managed to get it working last night.  IDK if it is the cause of my new breakout board or some other issue but I increased my delay time from 0uS to 5uS and it works perfectly now.
Offline ZASto
  •  434 434
« Reply #6 on: January 24, 2020, 07:44:51 AM »
As usual, too short Step pulses :)
Glad that you sorted it out.
