Hello Guest it is November 13, 2026, 09:39:41 AM
Author Topic: .tap code cant be found  (Read 8278 times)
« on: January 15, 2020, 03:45:23 PM »
Hello,
Not sure if there is any activity on here anymore.
I have an issue trying to load my files on Mach 3. All of the codes are brought in from V care 9.0. After selecting "load G code" The various folder selections open for the flash drive I am using. When clicking into the folder, or any folders, no .tap files can be found to load. I can go back into the file when not loading it, and open the code in notebook. Not quite sure what is going on.
Any help would be awesome
Re: .tap code cant be found
« Reply #1 on: January 15, 2020, 04:11:01 PM »
most likely the files have the wrong extension, they may be being generated and saved as .nc or .txt files. There is a setting,
can't quite remember where, in Mach3 that allows Mach to 'see' files with extensions like .nc and .txt.
  •  9,377 9,377
« Reply #2 on: January 16, 2020, 12:25:59 AM »
After you click Open Gcode File, in the lower box Files of Type, select All Files(*.*) or whatever file extension you require.
« Last Edit: January 16, 2020, 03:31:50 AM by Tweakie.CNC »
