Hello Guest it is November 10, 2026, 01:53:31 AM
Author Topic: Turning Wizard  (Read 23947 times)
Turning Wizard
« on: January 15, 2020, 12:54:54 AM »
Good day.
Can I get info how to write my own wizard.
From scratch. FOR DUMMIES. ME as the dummy.
  •  9,376 9,376
Re: Turning Wizard
« Reply #1 on: February 02, 2020, 01:30:07 AM »
Re: Turning Wizard
« Reply #2 on: March 10, 2020, 09:18:08 AM »
Good day.I have a inductive proximity switch fitted to my lathe with a Mach3 mod. It is a AE1/AP-1A.I want to use it foe speed and threadcutting. It is set up on my spindel to read once per revolution. Can you help me with the wiring and setup on pins and ports please? It is a PNP switcj.with 3 wires. Brown Black and Blue. Thank you
Offline TPS
  •  2,627 2,627
Re: Turning Wizard
« Reply #3 on: March 11, 2020, 03:23:34 AM »
first off all we Need to know witch BOB/Motion controler you are using.
Re: Turning Wizard
« Reply #4 on: March 11, 2020, 04:52:40 AM »
Hi. I have a Mach 3. Motion card
MKX-IV
Usb conection
Offline TPS
  •  2,627 2,627
Re: Turning Wizard
« Reply #5 on: March 11, 2020, 05:32:23 AM »
in this case you have to use a NPN sensor.
« Last Edit: March 11, 2020, 05:34:44 AM by TPS »
Re: Turning Wizard
« Reply #6 on: March 11, 2020, 06:15:36 AM »
Thank you. So if I change the PNP TO A NPN IT WILL WORK? I AM NOT SO CLUED UP ON ELECTRONICS.
Offline TPS
  •  2,627 2,627
Re: Turning Wizard
« Reply #7 on: March 11, 2020, 06:53:42 AM »
Normaly yes, but you never know on this chinese stuff, until you have tryed it.
Re: Turning Wizard
« Reply #8 on: March 12, 2020, 05:58:23 AM »
Thanks. I got a npn switch. Can you help me with the pin and ports please. I have it wired to the OV and 6-24V and pin 14 on input control ports.
Offline TPS
  •  2,627 2,627
Re: Turning Wizard
« Reply #9 on: March 12, 2020, 06:10:21 AM »
IMHO i would say set INDEX Input to port 1 pin 14.
but i do not have any documentation of your controller
