Hello Guest it is September 28, 2026, 10:48:26 PM
Author Topic: Z moves down after Ref All home and hits base  (Read 21774 times)
Re: Z moves down after Ref All home and hits base
« Reply #10 on: January 20, 2020, 02:09:04 AM »
Thanks again TPS !
Ok - so the Z moves up now.  I dont think my limits switches are switched on, as none of them work.  How do I switch them on?
In case they are faulty, I have attached a picture - do you know what this is?
Many thanks
Anthony
Offline TPS
  •  2,627 2,627
« Reply #11 on: January 20, 2020, 11:00:51 AM »
normaly first Thing is to figure out how they are wired to your Controller/ parallel port.
on the Picture you posted i can't se any wiring at all??!
and after the wiring is clear in Config -> Ports&Pins -> Inputs
« Reply #12 on: January 20, 2020, 02:20:27 PM »
Hi TPS, thankyou again. It seems that he wiring goes straight into the plug - I put a voltmeter and the voltages are shown.  the + was connected to the + of the voltmeter. it looks like all inputs go to Port 1?   Is -2.67V correct - I found that image online and it says its 5V input, but it is +.
The issue is, I dont think its a 4 wire sensor, uless there is resistors hooked up inbetween the sensor and the plug?
Thanks TPS,
Anthony
Offline TPS
  •  2,627 2,627
« Reply #13 on: January 21, 2020, 01:14:54 AM »
if it is an optical sensor, i think there should be an external power supply (5V) somewhere.
is there no Manual of the Controller box?
« Reply #14 on: January 22, 2020, 04:18:45 AM »
Thanks TPS.  There is no external power supply - the person who made it had everything in the box. No manuals.
So I suppose I need to open the box and  check the power supply to the sensor?
Offline TPS
  •  2,627 2,627
« Reply #15 on: January 22, 2020, 04:21:33 AM »
i think so.
