Hello Guest it is November 25, 2026, 06:04:38 AM
Author Topic: cant write to registry by Api C#  (Read 7813 times)
« on: December 27, 2019, 07:21:35 AM »
i use the Api to control the mach by c# and its work ok
now want to improve and also write into the registry by the api
but i got error in c# while try to get the registry handle
the c# code:
[DllImport(@"C:\Mach4Hobby\Mach4IPC.dll", EntryPoint = "mcRegGetHandle")]
        public static extern int mcRegGetHandle(int mlnst, string regname);
        private void manualloading(object sender, RoutedEventArgs e)
             int debug= mcRegGetHandle(0, "iRegs0/auto");
attach is the error from vs
System.AccessViolationException
  HResult=0x80004003
  Message=An attempt was made to read or write to protected memory. This condition usually indicates that another memory is defective.
  Source=<Cannot evaluate the exception source>
  StackTrace:
<Cannot evaluate the exception stack trace>
Offline smurph
  •  1,575 1,575
Re: cant write to registry by Api C#
« Reply #1 on: December 27, 2019, 02:16:17 PM »
The function signature is incorrect.  Where it your variable to receive the register handle?
Here is the C definition.
MACHAPI int MACH_APIENTRY mcRegGetHandle(MINSTANCE mInst, const char *path, HMCREG *hReg);
Steve
« Reply #2 on: December 28, 2019, 10:15:57 AM »
i try wit 3 argument  ,got same error
        public static extern int mcRegGetHandle(int mlnst, string regname,int hReg);
            int hreg = 0;
             int debug= mcRegGetHandle(0, "gRegs0/auto",hreg);
Offline smurph
  •  1,575 1,575
« Reply #3 on: December 28, 2019, 05:48:54 PM »
Still your function signature is wrong for returning a value in the third parameter.  It is a passed pointer.
Code: [Select]
[DllImport("Mach4Core.dll", CallingConvention = CallingConvention.StdCall)]
[return: MarshalAs(UnmanagedType.I4)]
[param: MarshalAs(UnmanagedType.I4)]  int mInst,
[param: MarshalAs(UnmanagedType.LPStr)]  string path,
[param: MarshalAs(UnmanagedType.U4), In(), Out()] ref uint hReg);
Steve
« Reply #4 on: December 29, 2019, 12:32:21 AM »
thanks a lot ,it work perfect
