Hello Guest it is November 13, 2026, 09:54:10 AM
Author Topic: porque usam tanto corrediças de gaveta na posição errada?  (Read 8107 times)
« on: December 26, 2019, 07:09:59 PM »
Ando vasculhando por aqui e por outros sites; e sempre vejo pessoas usando corrediças de gavetas deitadas, ou seja, a 90 graus da posição que geralmente elas funcionam nas gavetas.....alguém tem explicação para isto? Pergunto porque já comprovei em testes que usando na posição convencional quase não se tem folgas o que ocorre na outra posição e tende a aumentar com a utilização.
Dantas
Google translate;
I've been scouring around here and other sites; and I always see people using drawer slides lying at 90 degrees from the position that they usually work in drawers ..... does anyone have an explanation for this? I ask because I have already shown in tests that using in the conventional position there is almost no clearance what occurs in the other position and tends to increase with use.
Dantas.
« Last Edit: December 27, 2019, 12:39:41 AM by Tweakie.CNC »
  •  9,377 9,377
Re: porque usam tanto corrediças de gaveta na posição errada?
« Reply #1 on: December 27, 2019, 12:47:17 AM »
Hi Dantas,
Ideally, posts in this part of the forum should be made in English if you can.
The 'draw slides' make poor linear rails for CNC use. Linear rails which are purpose made for CNC use would be a much better investment in the long term.
« Reply #2 on: December 27, 2019, 07:52:57 AM »
Oops ... sorry. I just fear a wrong translation.
As for the statement that traction slides are bad I disagree. Of course the ones themselves are better but the investment difference is huge.
Dantas
