Hello Guest it is November 13, 2026, 09:38:11 AM
Author Topic: CNC XPro4  (Read 7839 times)
CNC XPro4
« on: December 23, 2019, 04:19:21 PM »
I'm using a XPro4 breakout board which has wiring for limit switches. I've got the switches connected to the board but no display on the Mach3 software. I get a tone from the computer when switches are depressed but no interrupt from the software. I'm sure it's my own stupidity but what do I need to do to rectify the situation?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: CNC XPro4
« Reply #1 on: December 24, 2019, 06:08:45 PM »
Common faults are:-
Board is not enabled.
Boards works at 3.3V,  Mach needs 5V.
Board needs more than one power supply.
Check if inputs need to be at 0V or 5V.
Re: CNC XPro4
« Reply #2 on: December 26, 2019, 06:10:13 PM »
Maybe check the obvious and check the ports and pins to make sure they are enabled
Cadcam Man
