Hello Guest it is November 23, 2026, 05:06:50 AM
Author Topic: I need HELP !!  (Read 43944 times)
I need HELP !!
« on: December 21, 2019, 10:02:09 PM »
So forever I have been trying to get my cnc machine working. I am using mach 3. I have tried setting up the spped of the movement of the access of anywhere between 800 and 1200mm per minute. I have also made my acceloration between 5 and 10% the speed. When I manually tell the x or the x or the z to move it all seems fine. But when I run a small program with lots of moves the machines has lots of problems and I loose steps and the machine seems to shutter. I am running the steppers at 1/2 step and have the step and dir pulse set at 15 each. I have 3 power supplies,1 for each y and 1 total for the x and z. I also have a separate 24 volt one for the Break out board, I do notice that the voltage starts to go down on the powere supples as they go on. Any ideas ????
  •  9,378 9,378
Re: I need HELP !!
« Reply #1 on: December 22, 2019, 12:31:04 AM »
1/2 step is not good for smooth movement - it is more usual to use 1/8 or 1/10.
Could you post more details of your machine and controller - a couple of pictures would be good.
Re: I need HELP !!
« Reply #2 on: December 22, 2019, 12:50:10 AM »
It is a custom machine.  I built from scratch.  It has 425oz motors and 4 controller that are set at 4.2amp.  It has one of those inexpensive break out boards that attached to my parallel port.  I am running win 7 32 bit.
Re: I need HELP !!
« Reply #3 on: December 22, 2019, 05:58:04 AM »
Post the following:
1. Stepper motor information - from who, model number,  motor curve, etc
2. Drive information
3. Screw information
3. Power supply information
4. XMl file you are currently using
5. The program you are using ( complete not snippet of code )
The above information will save us a  lot of time. I'll refrain from making  comments until the above is posted.
Re: I need HELP !!
« Reply #4 on: December 22, 2019, 09:00:00 AM »
Motor is Act motor model 23HS2442
Driver is HY-DIV268N-5A.  It is set at 1/2 step and 4.2A
screw is 8mm screw.  one turn moves it 8mm
https://openbuildspartstore.com/8mm-metric-acme-lead-screw/
Re: I need HELP !!
« Reply #5 on: December 22, 2019, 09:02:14 AM »
Power supplies are DROK Adjustable DC Power Voltage Converter AC 110V-220V to DC 0-48V Module 48V 10A
https://www.amazon.com/gp/product/B01MV4249T/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
XML FILE - I have no idea on what you mean by this
Re: I need HELP !!
« Reply #6 on: December 22, 2019, 09:14:09 AM »
and finally the code
Re: I need HELP !!
« Reply #7 on: December 22, 2019, 09:46:59 AM »
The profile you use or created to run Mach3 is located in the Mach3 directory on your computer
and is saved as an XML document. It contains all the settings etc. you defined for the machine.
Make a copy of that file and rename it to have a unique name ie; NEED HELP and post it.
Re: I need HELP !!
« Reply #8 on: December 22, 2019, 10:14:04 AM »
I believe this is it.
Thanks Steven
Re: I need HELP !!
« Reply #9 on: December 22, 2019, 11:24:27 AM »
Post info on the break out board
Can you post a link to where you purchased the stepper motors from.
The ACT company does not  list that particular model stepper.
