Hello Guest it is October 24, 2026, 02:48:16 PM
Author Topic: Homing - Reverse Direction?  (Read 7696 times)
« on: December 19, 2019, 10:12:43 AM »
I've recently set about doing an overhaul/rewire on an old Pacer Cadet router, mechanically it was fine but the electronics were shocking to say the least.
I've set about re-wiring it and also took the opportunity to upgrade to an ESS and MB3 breakout along with some G201X drives, everything is working as it should but I've hit a wall now I'm trying to get the machine to home correctly.
The Cadet is setup to home bottom right as you look at the machine. On the Mach 3 install that came with the machine, which has now died, when incremented from the home position X was positive and Y negative, this worked fine as Fusion can generate gcode to reflect this.
On the Mach 4 install I either get it to increment correctly or home correctly, if I flip the dir pin I get it to increment positively but then the home direction is wrong.
Is there a simple flip home position button that I'm missing, or will I be better off just moving the limit switches so it homes from bottom left?
Any help would be most appreciated.
James
Re: Homing - Reverse Direction?
« Reply #1 on: December 19, 2019, 10:36:40 AM »
From the top menu go to Configure>Control and then select Homing/SoftLimits. The first column is Home Dir where you can select the homing direction for each axis
« Reply #2 on: December 19, 2019, 11:31:31 AM »
Thank you!!! Hours I've spent looking for that today and it was right in front of me!!! You've probably just saved me hours tomorrow as well!! Cheers!
