Hello Guest it is October 21, 2026, 09:05:29 PM
Author Topic: M3 Probing error THC Pokeys  (Read 20193 times)
Re: M3 Probing error THC Pokeys
« Reply #10 on: July 07, 2021, 03:38:48 PM »
How have you turned anti dive off ?   I`m struggling to understand what values to use for the adjust rate
You use Mach4 or Mach3? For mach4 you go to configure/plugins/regfile and there are all the options for THC and more, you find the nf/thc/AntiDiveState and change it to 0 so it be disabled.
Adjust rate is the % of the feedrate you want the TCH to make corrections on Z Axis. If your Z axis velocity is 2000mm/min and you put 10% adjust rate then your THC will correct with 200mm/min.
Are more options but if you use Mach3 aren't for you and better ask Mach3 topics for help.
« Reply #11 on: July 08, 2021, 02:35:59 AM »
Thanks for the explanation, I use Mach4 but notice the Regfile doesnt match what I have set in the GUI ?     in fact its in Imperial and not Metric I will have to do some experimenting.
« Reply #12 on: July 08, 2021, 04:00:28 AM »
Check this nf/thc/DeadBandWidth default is 5, if measured voltage is -/+5V then the THC is disabled. I have it to 1 but my electronics measure very low voltage 0-5V.
Yes the default values is inches but Mach4 not understand metric/inches, just put the values you want.
« Reply #13 on: July 08, 2021, 07:31:55 AM »
Great thanks for the help, I will be doing more testing later today.
« Reply #14 on: September 24, 2021, 08:55:08 PM »
Hello I’m really struggling with my pokey 57 and the plasma sense thc I can’t get it to work if I do a test run plasma cutter on it arc but  won’t read out the voltage someone any idea
« Reply #15 on: March 07, 2022, 08:50:57 AM »
You have to set the property of the Actual Voltage DRO to the Pokeys PlasmaSens HV register.
