Hello Guest it is November 23, 2026, 04:07:00 AM
Author Topic: Using "GOTO ZERO" switch, Z axe stay in low (-) position  (Read 7015 times)
« on: December 07, 2019, 12:04:26 AM »
Hi
My problem is - from recently, when i use "goto zero" command switch, my z-axe no more raise up to safe distance (+20mm) and then go to x0 y0 position, and then z0!
Instead of that z axe stay in curent (low) position and x and y go to 0.
- if z is in (minus) position, then movement crack my bit
How can I set this so before x and y go homing to 0, first raise z axe to safe heigh say (+20mm)?
thanks for help
