Hello Guest it is October 20, 2026, 03:02:34 PM
Author Topic: [MACRO] Move the Y axis after job end by a predefined amount with MaxY() ?  (Read 7131 times)
I'm trying to park the tool dynamically after the machine ends cutting and I came upon the MaxY() function, which returns the Machine coordinates of an axis from a gcode.
Problem is, this macro is evaluated only while the tool path is generated, that is, before actually cutting. So if I zero my axis after loading the cut file, the final move is not where I expected it, because the tool path took into account the old zeros.
Code: [Select]
'Define the axes
Dim Xaxis As Integer
Xaxis = 0
Dim Yaxis As Integer
Yaxis = 1
Dim Zaxis As Integer
Zaxis = 2
'Define the X&Y work dimensions
Dim X_axis_length As Double
X_axis_length = 1300.0
Dim Y_axis_length As Double
Y_axis_length = 2550.0
'Define variables to store the machine position for the Y axis
Dim Y_MaxReachedMachinePos As Double
'Get Y Axis max reached value of machine coordinates during the cut
Y_MaxReachedMachinePos = MaxY()
' Move Z axis to Safe_Z position
GotoSafeZ()
While IsMoving()
Wend
'Compare which of the 3 table areas the tool reached to know how far it can be moved in the Y direction after job finished.
If Y_MaxReachedMachinePos <= (Y_axis_length/3) Then
Code "G0G53 X20.0 Y" & Y_MaxReachedMachinePos+600.0 'Move the tool 60cm in the Y direction
'While IsMoving()
'Sleep 100
'Wend
ElseIf Y_MaxReachedMachinePos > (Y_axis_length/3) And Y_MaxReachedMachinePos <= (Y_axis_length*2/3) Then
Code "G0G53 X20.0 Y" & Y_MaxReachedMachinePos 'Move the tool 45cm in the Y direction
'While IsMoving()
'Sleep 100
'Wend
ElseIf (Y_MaxReachedMachinePos+450.0) < Y_axis_length Then
'While IsMoving()
'Sleep 100
'Wend
Else
Code "G0G53 X20.0 Y" & Y_axis_length 'Move the tool all the way back in the Y direction
'While IsMoving()
'Sleep 100
'Wend
End If
Y_MaxReachedMachinePos=0
Is there a way to accomplish this? Like, executing the macro only after the machine starts cutting, for isntance?
Enabling "Ignore M calls while loading" didn't work.
Thanks in advance, Alejandro.
Offline TPS
  •  2,627 2,627
Re: [MACRO] Move the Y axis after job end by a predefined amount with MaxY() ?
« Reply #1 on: November 15, 2019, 02:41:48 PM »
that is the Problem between zeroing an axis and home a axis (by using a Limit Switch).
if you only "Zero" a axis you never know where this Zero is based on max of axis movement.
if you home an axis by using a Limit Switch you allways know exactly where the axis is (in machine
coords) by using G53.
