Hello Guest it is November 09, 2026, 11:29:53 PM
Author Topic: Setting back off distance from homing switches in Mach 3  (Read 35313 times)
« on: November 10, 2019, 05:38:17 AM »
So where do I set the back off distance to keep my machine from homing on the limit switches under Mach3?
  •  9,375 9,375
Re: Setting back off distance from homing switches in Mach 3
« Reply #1 on: November 10, 2019, 05:49:28 AM »
Within Mach3 there is no setting for limit switches back-off distance - the axis will only back-off until the limit switch changes state.
You can then use an Offset or, within the Button, use VB to set the axis position/s of your choice.
« Last Edit: November 10, 2019, 05:55:53 AM by Tweakie.CNC »
« Reply #2 on: November 10, 2019, 06:38:42 AM »
That's just it. It's not backing off at all. When it homes it stays against the switch
  •  9,375 9,375
« Reply #3 on: November 10, 2019, 06:46:36 AM »
Then you have a problem with your Mach3 installation which could be...
Software, in which case re-install Mach.
Hardware, which could be electrical noise causing a false signal or a poor quality switch.
Try increasing the Debounce setting in Config / General Config and see if that makes a difference.
« Reply #4 on: November 10, 2019, 07:55:44 AM »
what controller are you using? if its the HXC goto plugin control / Hxc Ncpod config and you have an option for homing pull off. It sets the distance for the duel stage homing and  also like you want the offset distance after homing. Hope this helps
My only fear is my wife will find out how much I spend on my hobby.
« Reply #5 on: November 14, 2019, 01:45:46 PM »
Ok, reinstalling Mach3 fixed the issue.
  •  9,375 9,375
« Reply #6 on: November 15, 2019, 01:09:46 AM »
