Hello Guest it is October 17, 2026, 11:55:31 AM
Author Topic: Limit switch issues  (Read 9096 times)
Limit switch issues
« on: November 07, 2019, 10:56:18 AM »
Please help,
After a long break away from my Router machine I decided on a rebuild.
I'm now using Mach4 with an ESS Smooth stepper
All 3 axis motors are running fine and I can Jog in all directions (until I configure my Limit Switches)
I have used 5 Limit Switches.
One for the Z Axis top of Travel. Z-
One for X Home and X - (Shared)
One for X +
One for Y Home and Y- (Shared_
One for Y+
I keep getting messages like 'Cant Jog towards limit switches etc'
Can anyone help me getting the correct boxes ticked in Mach4 setup and ESS Setup. I'm getting my knickers in a right twist. Need help.
George
One step at a time!
Re: Limit switch issues
« Reply #1 on: November 07, 2019, 02:31:41 PM »
I'm not sure if I have assigned the switches to the correct position on my Router Any help here would be appreciated.
« Last Edit: November 07, 2019, 02:41:13 PM by Len-Tikular »
One step at a time!
  •  9,374 9,374
« Reply #2 on: November 10, 2019, 12:50:23 AM »
Your Y axis looks reversed to me but with a router it all relates to the position that the operator stands in relation to the machine. This video explains the Right Hand Rule  https://www.youtube.com/watch?v=AKwlzIJG5lo
« Reply #3 on: November 10, 2019, 08:15:31 AM »
Not sure if I have the image correct but the z looks wrong  Z- should be below the home and as tweakie stated the Y axis looks reversed :)
My only fear is my wife will find out how much I spend on my hobby.
« Reply #4 on: November 11, 2019, 01:35:36 PM »
Thanks Gents, I have reversed my Y Axis  as suggested Y+ Is now assigned as Y+ (&  Y Home) Opposite end is Y- (&  Y Limit)
X + is also X Home and X- is X Limit
and have also designated Z top of travel to Z+ (& Home)
I'm still unsure if my Limit and home switches are correctly positioned.
I'm getting confused with the table in the ESS Setup. (Attached)
George
« Last Edit: November 11, 2019, 01:52:25 PM by Len-Tikular »
One step at a time!
