Hello Guest it is November 24, 2026, 02:06:13 PM
Author Topic: Mach3-The machine stop in execut program  (Read 11408 times)
« on: October 28, 2019, 07:27:22 AM »
hi everyone,
I'm new in this site, and I need help.
I have a machine controlled by mach3.
The operative system is Win7, and used a USB card interface.
(link)
https://www.google.com/imgres?imgurl=https%3A%2F%2Fwww.buildyourcnc.com%2Fimages%2FIMG_20181228_145312__01-800.jpg&imgrefurl=https%3A%2F%2Fbuildyourcnc.com%2Fitem%2FelectronicsAndMotors-electronic-component-breakout-Mach3-USB-Board&docid=2HKAsEYfKSQ2-M&tbnid=b_h_yNX5n8dbDM%3A&vet=10ahUKEwjklvjc9r7lAhVtIrkGHW4ZC9gQMwhGKAIwAg..i&w=800&h=654&client=firefox-b-d&bih=654&biw=1366&q=usb%20mach3&ved=0ahUKEwjklvjc9r7lAhVtIrkGHW4ZC9gQMwhGKAIwAg&iact=mrc&uact=8
I have problem when I run a program, in a "program run mode" in mach3.
The machine normal start to run, but then y stop at 25 second(proximately).
I read in many sites that this problems can be the watch dog(in "general config"), so y see this configiguration, and it is not activated.
Can be any know something about that?
Thanks very much
Ariel
Re: Mach3-The machine stop in execut program
« Reply #1 on: October 28, 2019, 12:08:25 PM »
is Mach3 licensed?. In absence of a valid license file it will run in Demo mode for 500 lines of Gcode trhen stop.
« Reply #2 on: October 28, 2019, 12:18:48 PM »
Hi Craig,
Yes, de Mach3 its Licensed.
In fact, I verify the program line stop, and is less than 50.
Ariel
« Reply #3 on: October 28, 2019, 02:22:11 PM »
Mach3 lathe Demo line limit is 50 lines, mill limit is 500 lines.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #4 on: October 30, 2019, 07:46:20 PM »
If you are using the Licence that came with the board then it will always fail to work.
