Hello Guest it is November 07, 2026, 10:40:36 AM
Author Topic: Lazy Cam Problem  (Read 10732 times)
Lazy Cam Problem
« on: September 11, 2007, 08:59:11 PM »
I am learning how to use lazycam and have a problem when I process a DXF.
When I post to Mach3 the routine cuts fine, BUT it also cuts all the lead in symbols.
What is it that I am missing.
WJF
Re: Lazy Cam Problem
« Reply #1 on: September 13, 2007, 09:03:37 PM »
Greetings, WFJ. Have you tried to turn off the leadins? When you say lead-in symbols, do you mean the straight, slant, or circular lead-ins? Some might use lead-ins but I use plunge-able router bits and cut in wood, so I don't need 'em.
« Reply #2 on: September 14, 2007, 03:26:41 AM »
Thanks for the reply.
That solved the problem
wjf
