Hello Guest it is October 22, 2026, 09:36:41 PM
Author Topic: How to change post processor to go to Z zero only at program end.  (Read 15582 times)
Re: How to change post processor to go to Z zero only at program end.
« Reply #10 on: October 23, 2019, 08:40:30 PM »
Disregard! Dummy me!!
I was not writing the machine configuration to the post processed file.
All is well for this issue!
Offline Stuart
  •  311 311
« Reply #11 on: October 24, 2019, 01:51:07 AM »
Go to the fusion/hsm post library and down load the current m4 mill post that has the code to enable g30.
As I said to you in my first post to you get over to the forum that can help you they are the ones who produce the posts for their software
« Reply #12 on: October 24, 2019, 08:45:50 AM »
I asked Autodesk to add G30 to the safe retracts last year.  As long as your post isn't older than 10/12/18 then you should have the option to use G30 as well.
That way you can move your table Front and Center once the program is finished.
But, originally, you just wanted the Z to retract only; removing the writeRetract(X, Y); will cause only the Z to retract.
Chad Byrd
