Hello Guest it is November 08, 2026, 02:35:20 AM
Author Topic: Mach4 and Huanyang HY series VFD  (Read 7172 times)
« on: October 13, 2019, 09:51:27 PM »
There is a plugin for Mach3 that allows you to control a Huanyang HY Series VFD that uses a non-standard modbus protocol via a USB to RS-485 converter.
Does such a plugin exist for Mach4, or do I need to upgrade my VFD to one with a standard modbus implementation?
If I need to upgrade my VFD, can anyone recommend a Mach4 compatible one that will put out 1.5kw and operate on 110Vac?
This is the last piece keeping me from going from Mach3 to Mach4...
Re: Mach4 and Huanyang HY series VFD
« Reply #1 on: October 13, 2019, 10:53:45 PM »
there have been a few posts about the early model Huanyang VFDs that require a special plugin.
To my knowledge no-one has written a similiar plugin for Huanyang/Mach4.
The latest model Huanyng VFDs ARE standard ModBus, I think the models are appended with a suffix -GM, or GS or
similar. Clearly Huanyang must have been getting flak because of their non standard interface.
I personally have always had good success with Delta VFDs.
« Reply #2 on: October 20, 2019, 10:18:35 AM »
I am running my Huanyang GT series controlled via Modbus thru Mach4.  Works great!!!
