Hello Guest it is October 30, 2026, 11:52:10 AM
Author Topic: Input pins Waltz!  (Read 18162 times)
Input pins Waltz!
« on: September 19, 2019, 10:47:11 PM »
Hi!
I've run into a little problem with my prox switches and MACH3. The state requirements toggle...yes....toggle! What I mean is that I set the Active LOW setting and the status light goes off which is what I want. But shortly after at the same setting the status light went back on... then I swap the setting to Active HIGH and the status light goes off....which is what I want.... but shortly after... it changed again and I must change the setting back to Active LOW. This is with no obstruction in front of the prox therefore NO real output change. And all of this happens on more than one axis and keeps me from sleeping!!! Even the homing is messed-up.... all of my axis home except for X, it just reaches the home prox and stops, no OFF the switch function occurs. HELP!! :-\
I am currently using NPN NC Proxes, is that ok?
Thank you!
Tom
