Hello Guest it is October 31, 2026, 12:58:10 PM
Author Topic: mach3 turn threading issue  (Read 48807 times)
Re: mach3 turn threading issue
« Reply #10 on: September 15, 2019, 09:20:27 PM »
Do you have a licence for Mach?
« Reply #11 on: September 16, 2019, 06:05:40 AM »
all good now
 took the tick out of use spindle feedback in sync modes box
« Reply #12 on: September 17, 2019, 01:52:05 PM »
not all good now the thread looks bad .
the mach3 threading pdf said it needs the spindle feedback in sync modes boxed checked.
is this correct?
are there any other configuration settings that need to be input
thanks
« Reply #13 on: September 18, 2019, 05:37:01 AM »
chessie,
You are using an external motion device and should have said so right from the get go.
Have no experience with the UC400 ETH controller. There should be a installation
and user guide available for use with Mach from the seller / manufacturer. There are product downloads available
for the 400. Did you have a read of that info?
If someone has experience with  UC400 ETH they can help you and may reply
here. If not,  I would suggest that you go back to the manufacturer for  specifics.
The mach3 threading pdf does not address the UC400 ETH.
« Last Edit: September 18, 2019, 05:47:48 AM by RICH »
  •  9,375 9,375
« Reply #14 on: September 18, 2019, 06:51:11 AM »
As Rich has said you need to ask any questions you have regarding threading on the CNC Drive forum http://forum.cncdrive.com/viewforum.php?f=22
« Reply #15 on: September 18, 2019, 08:21:14 AM »
Gee guys I tried to answer the question. (;-)
« Reply #16 on: September 18, 2019, 08:28:48 AM »
OK thanks what do u have to do or buy to fix this please
  •  9,375 9,375
« Reply #17 on: September 18, 2019, 09:05:54 AM »
Sorry TP (I missed your posting).
« Reply #18 on: September 18, 2019, 09:51:18 AM »
I see the user has made an inquiry over at the UCCNC forum. Lets see where that leads to as far as an answer.
« Reply #19 on: September 18, 2019, 11:31:16 AM »
are you saying this wont work with a disc and proximity sensor connected to index ?
If not do you have a solution
cheers
