Hello
Guest
it is
November 25, 2026, 11:00:53 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mach3 turn threading issue
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: mach3 turn threading issue (Read 49625 times)
Overloaded
4,923
Re: mach3 turn threading issue
Reply #30 on:
September 19, 2019, 06:58:55 AM »
Read all the info describing the encoder resolution in relation to the speed of the signals.
And, the notes about QUALITY high speed onto-couplers that some BoB's utilize and so many other lower quality ones do not.
Logged
BR549
6,965
Reply #31 on:
September 19, 2019, 07:11:58 AM »
I would keep teh Pulse count low as in 100-400 PPR and yes teh ABZ is what you want. as to wiring it up I have no idea how your machine is wired. Only you will know that.
Logged
BR549
6,965
Reply #32 on:
September 19, 2019, 07:20:25 AM »
When you get the encoder set up TRY teh Mach3 G32/G76 routines to see if they work. The testing I did with this was 3 years ago.
Logged
chessie
44
Reply #33 on:
September 19, 2019, 11:36:59 AM »
thanks for the help
i just updated the firmware for the uc400eth .
its working and threading lovely now using the hall effect proximity switch for some reason . i can now have the spindle sync ticked in mach3 and it works
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
