Hello Guest it is November 23, 2026, 03:57:29 AM
Author Topic: Does anyone have a "Firmware" (post processor) file for Simplify3D to Mach4?  (Read 7688 times)
Thanks in advance.
Hi poppabear,
if you have a post that produces good Gcode for Mach3 then it should work for Mach4 also.
I have encountered only one instance where code that runs on Mach3 fails under Mach4. Even then its
because Mach4 sticks more closely to ANSI Gcode.
Hi Joe,
Thanks, but not really what I am asking/looking for, I need a "Simplify3D" Post processor (firmware file),
for the CAM software for out put to Mach4. I am very familiar with both mach3 & 4 as far as
what and how they run. I was/am hoping some one has the post so I do not have to recreate it,
since it is a PIA.
so you don't have a Simplify3D post for Mach3 either?
« Last Edit: September 07, 2019, 03:14:55 PM by joeaverage »
