Hello
Guest
it is
November 23, 2026, 03:26:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach4 General Discussion
Warp9, Mach4, and SSD drive
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Warp9, Mach4, and SSD drive (Read 7277 times)
Plasron
11
on:
September 04, 2019, 11:49:14 AM »
We have a windows 10 laptop 64 bit , I found out it has a SSD, Solid State Drive, will this computer work with Mach4 and Warp9 ESS ?
Thanks in advance
Ron
Stuart
311
Re: Warp9, Mach4, and SSD drive
Reply #1 on:
September 04, 2019, 01:07:28 PM »
Why wouldn’t it work?
Yes ssd are faster than HDD been using on the the cnc controller Mach4 ind ESS touch screen
Plasron
11
Reply #2 on:
September 04, 2019, 02:36:42 PM »
Thanks Stuart
We may go back to Mach3 this Mach4 is way over my head.
I was able to get the X Motor to make a slight sound, the Motors tab in Mach4 is beyond me as to how to get them to run.
Thanks again
Ron
thosj
542
Reply #3 on:
September 04, 2019, 07:56:15 PM »
Ron,
IMHO it would be worth the effort to get Mach4 running. Warp9 has a great how-to that'll step you right thru the process. If you've got a working machine running on Mach3 you're most of the way there.
Tom
Tom
Stuart
311
Reply #4 on:
September 05, 2019, 01:07:58 AM »
Ron
In Mach 4 motors tab
Click check box then click the name and turn it blue then you can config the motor
Print
Pages:
1
Go Up
« previous
next »
