Hello Guest it is November 18, 2026, 10:55:41 AM
Author Topic: Warp9, Mach4, and SSD drive  (Read 7251 times)
« on: September 04, 2019, 11:49:14 AM »
We have a windows 10 laptop 64 bit , I found out it has a SSD, Solid State Drive, will this computer work with Mach4 and Warp9 ESS ?
Thanks in advance
Ron
Offline Stuart
  •  311 311
Re: Warp9, Mach4, and SSD drive
« Reply #1 on: September 04, 2019, 01:07:28 PM »
Why wouldn’t it work?
Yes ssd are faster than HDD been using on the the cnc controller Mach4 ind ESS touch screen
« Reply #2 on: September 04, 2019, 02:36:42 PM »
Thanks Stuart
We may go back to Mach3 this Mach4 is way over my head.
I was able to get the X Motor to make a slight sound, the Motors tab in Mach4 is beyond me as to how to get them to run.
Thanks again
Ron
Offline thosj
  •  542 542
« Reply #3 on: September 04, 2019, 07:56:15 PM »
Ron,
IMHO it would be worth the effort to get Mach4 running. Warp9 has a great how-to that'll step you right thru the process. If you've got a working machine running on Mach3 you're most of the way there.
Tom
Tom
Offline Stuart
  •  311 311
« Reply #4 on: September 05, 2019, 01:07:58 AM »
Ron
In Mach 4 motors tab
Click check box then click the name and turn it blue then you can config the motor
