Hello Guest it is October 15, 2026, 03:14:39 AM
Author Topic: Pause Lua script mach4  (Read 32039 times)
Re: Pause Lua script mach4
« Reply #10 on: August 21, 2019, 03:29:46 PM »
OK, good.
Yup, running dwell in Gcode is as good a way as any. I would just use a single line or edit Katz function to take a time parameter if it was something i might use in different places.
The code below should also check the type of dwell and convert to a number or error out if it can't be converted.
Code: [Select]
function wait(dwell)
local defaultDwell = 250
if (dwell == nil) or (dwell < defaultDwell) then --No dwell passed or a shorter dwell than the motion device can process will cause errors
dwell = defaultDwell
end
local GCode = string.format("G4 p" .. tostring(dwell))
rc = mc.mcCntlGcodeExecuteWait (inst, GCode) ---wait for time of dwell
--Do something here if rc ~= 0 because you have an error
end
--Then use it like this
wait(100) --will wait for 250 milliseconds == .25 seconds because it is less than default defined in function
wait() --will wait for 250 milliseconds == .25 seconds because dwell is not defined so function will define as default
wait(500) --will wait for 500 milliseconds  == .5 seconds
Don't use it like this though..........
Code: [Select]
wait("10 seconds") --will cause problems if the dwell type check I mentioned above isn't added
« Last Edit: August 21, 2019, 03:43:09 PM by Chaoticone »
« Reply #11 on: November 03, 2022, 08:30:08 AM »
why doesn't wx.wxMilliSleep() work in signal script
« Reply #12 on: November 01, 2023, 06:12:51 AM »
i use this:
function waiit()
   local GCode =""
            GCode = GCode ..string.format("G4 p500")
            mc.mcCntlGcodeExecuteWait (inst, GCode) ---wait 0.5 second
end
Hi Chaoticone,
Do you agree that this is a valid solution or is it still dangerous for the reasons mentioned above?
Many thanks, Dan
