Hello
Guest
it is
November 16, 2026, 03:40:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
pockets cuts undersized when cutting but contours are accurate
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: pockets cuts undersized when cutting but contours are accurate (Read 21706 times)
buddhi champika
2
on:
August 08, 2019, 02:37:35 AM »
hello guys,
when I'm cutting pockets the pocket get 0.5mm less, there is nothing wrong with the CNC cause when cutting contours it gets cut accurately.
please check the files below
Thank You!
Logged
alextulanov@gmail.com
4
Re: pockets cuts undersized when cutting but contours are accurate
Reply #1 on:
January 21, 2020, 04:08:20 AM »
I also have this problem.
Logged
jim711
1
Reply #2 on:
May 20, 2020, 01:23:48 PM »
Have you checked your bit with a micrometer?
Logged
Print
Pages:
1
Go Up
« previous
next »
