Hello Guest it is November 13, 2026, 09:36:38 AM
Author Topic: Ethernet Smooth Stepper with THC  (Read 8100 times)
« on: August 04, 2019, 03:38:02 PM »
Hello,
I've searched this forum and other forums on the internet but I can't seem to find the answer.
I want to use THC with ESS and Mach3. I've got a signal (the up and down leds are moving). THC is on and the curr value is changing to the min and max setpoint. Unfortunately the Z-axis doesn't move with the changes the proma thc makes to the curr value. When I click 'go to zero' the z-axis moves to the curr value set by the THC. So everything works but the z movements are not "live/active". Does anyone know what I did wrong?
Paul van Hoek
Offline TPS
  •  2,627 2,627
Re: Ethernet Smooth Stepper with THC
« Reply #1 on: August 05, 2019, 12:06:06 AM »
do you have the Torch On Signal wired and working?
« Reply #2 on: August 05, 2019, 03:05:08 PM »
Yes, wired and checked. The torch on light turn on when the torch ignites or when I run the test mode on the proma thc.
