Hello Guest it is November 13, 2026, 11:33:09 AM
Author Topic: transposing when routing  (Read 10538 times)
« on: July 30, 2019, 09:01:26 PM »
I am new. I have mach 3 with Ethernet smooth stepper and ever thing appears to be right. Down loading trail version of vcarve pro and trying to run the demo sign. It looks good on mach 3 screen but as the router runs it routes the lettering backwards, example is: (Avalon) but routes it like this: nolavA. Its does a very nice job but just backwards. Maybe a setting. I have researched and found very little on it. Has anyone had this issue?
Re: transposing when routing
« Reply #1 on: July 30, 2019, 09:09:26 PM »
I think you have the one axis directions back to front.
Have you followed the right hand rule when assigning axis directions? All CAD/CAM will asume
that axis orientation.
« Reply #2 on: July 31, 2019, 02:52:03 AM »
« Reply #3 on: July 31, 2019, 06:17:56 AM »
I did watch the video and I think understand what he was saying, but where are the changes made in Mach 3? I don't think I have come across that portion in mach 3 so I don't think I change that.
« Reply #4 on: July 31, 2019, 09:45:09 AM »
to reverse the direction of one axis, the X axis say......you can reverse the direction of the motor by swapping the
polarity of one winding of the motor OR you can do it in software.
Config/Ports and Pins/Motor Outputs.....reverse the direction signal.
« Reply #5 on: July 31, 2019, 06:31:39 PM »
That fixed it.
