Hello Guest it is October 22, 2026, 08:43:33 PM
Author Topic: Need someone with brains to help me with mine  (Read 18198 times)
« on: July 23, 2019, 09:12:11 AM »
I need help creating a brain that will turn on a relay (output #1) when I press the (Cycle start) button. Then when the program is finished to turn it off.  This relay is used to turn a long arm quilting machine on and off.  I have done it with M3 (on) and M5 (off) by putting it in my gcode this works only if my thread does not break. That never happens it always breaks. So right now when my thread breaks I have to press the manually press the (Feedhold) button to pause the program, then press the (spindle) button to stop the sewing machine.  Then once I have re threaded the machine and stepped the program back some number of steps I need to press the (cycle start) button to continue the program running and then press the (spindle) button to start the machine. I am using Mach3.
« Last Edit: July 23, 2019, 09:24:32 AM by pcbguro »
Offline TPS
  •  2,627 2,627
Re: Need someone with brains to help me with mine
« Reply #1 on: July 26, 2019, 01:07:28 PM »
brain attached
« Reply #2 on: August 07, 2019, 07:24:13 AM »
Thank you TPS that works for me.
